Veebyes
Jan 11, 2015Explorer II
Old-Biscuit wrote:
Usually access is done via a three sided window cut in underbelly......easier than trying to remove/reinstall a section
Have you tried spraying a lube (silicone or dry lube) down shaft/cable end while opening/closing valves?
Of course this may take more than one try. Fittings inside the underbelly may not be where you think they are.
Better to make one large access than to make a bunch of small mistakes.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
