SoundGuy
Aug 22, 2018Explorer
DutchmenSport wrote:
If you disconnect the battery, plug into shore power, and try to open or close the slides using the converter only, they won't work.
SoundGuy wrote:
Not universally true. Several times I've operated the slide, awning, and tongue jack using only the on board WFCO 8955 converter for source power. Works just fine. :B
Lantley wrote:
I imagine on some units the slides will work without a battery when on shore power. However the more prudent design is for them to operate on 12 volt battery power.
Shore power may not always be available but a charged battery should always be available.
A non-issue as I've also powered the slide, awning, and tongue jack by simply powering the trailer from the truck which is always "available". ;)
About RV Newbies
