rexlion
Nov 02, 2020Explorer
If it had the larger engine, it could tow 3500. That tells me that structurally it can handle it. But the drive train is the limiting factor. I note that you are in FL. If you were taking short camping trips close to home in the flat lands of FL, and if you kept your speed under 55 (wind resistance increases exponentially as speed increases), you could do it. Maybe add an extra transmission cooler. And don’t use the overdrive gear.
Keep in mind that dry weight ratings of trailers are without options, and probably without LP tanks or battery. You’d probably be in the 2000-2300 lb range, ready for camping. The vehicle will be very slow to accelerate and really sluggish up hills.
About RV Newbies
