- ScottGNomadThe fans will run and they don't care that you are dry camping.
- Second_ChanceExplorer II
LIGirlatheart wrote:
Thank you Rob - that's what I thought. Yes its on a slide. So would this also be using more gas as well then. we never noticed the noise of the fan running. So it get more of a workout in a slide.
No - it's not using any more gas. It's just trying to get rid of the heat generated by the cooling unit. The fans will run whether the frig is on gas or electric, too.
Rob - LIGirlatheartExplorerThank you Rob - that's what I thought. Yes its on a slide. So would this also be using more gas as well then. we never noticed the noise of the fan running. So it get more of a workout in a slide.
- Second_ChanceExplorer IIThe fan(s) on the back of evaporative RV friges is (are) thermostatically controlled and will run whenever the temp of the cooling unit reaches a certain level. If the frig is in a slide, the fan(s) will run more than if the frig is not in a slide. This is due to venting straight up in a non-slide frig. What you are describing sounds perfectly normal.
Rob
About RV Newbies
