Wow pretty harsh words from some one that does not even use the dump station.
Nope, not harsh in the least. Quite accurate actually. Terryallen is 100% correct. If you are going to stress that much over being delayed, then plan accordingly. Period. It's not someone else's issue if you put yourself on that tight of a time schedule. While I'll agree common courtesy should be used it also extends both ways-patience is a virtue that should be practiced far more often on here than it is. Too much "do as I say and not as I do". I can guarantee many of you are not as quick as you think you are.
