wa8yxm wrote:
There are several options, ONE may actually work...
First: Atwood makes a "10 gallon water heater that fits in a 6 gallon hat" by heating the water much hotter than normal then mixing cold and hot via a thermostatically controlled valve it can deliver 10 gallons at 120 Degrees..
Downside, uses a lot more energy, and is much more complex.  but that is 2/3 more hot water.
Second. Some water heaters you can use GAS and ELECTRIC AT THE SAME TIME and if you use the cut off valve when soaping up this can last much longer.
First off...
OP has a Suburban 6 gal and the Atwood WHs (6,10 or XT models) will not fit on Suburban opening w/o sidewall mods
Secondly....
Both Atwood and Suburban can be heated using both electric/propane at same time IF they are combo water heaters.
OP has a 6 gal combo WH so his choices are Both heat sources, not leave shower water running, changing out t-stats to higher temp/mixing in more cold water and changing out shower head.
Anything else will require modifications and replacement of WH
