bukhrn
Mar 21, 2014Nomad
ah64id wrote:Not exactly, all the adapter does is, allow you to plug your 30A cord into a 50A receptacle, your RV will only allow you to use 30A.CarpFishermanAndWife wrote:
So the only reason we need to use our 30/50 connector is if we have to use a 50 amp site and we use our connector to downgrade the 50 amps to 30 amps for our TT, correct?
Correct.
As for your dealer, He's full of it, I run my AC & microwave all the time on 30A with no problems.
As for a Surge Guard/ Protector, I use one, more for low voltage, but it protects against high or low voltage, many folks don't use them & get along just fine, but it only takes one time to make it worth while.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
