calamus
Nov 29, 2013Explorer
barney bugle wrote:
Thanks guys.im a little confused as I have seen some 150 psi with lower cfm than say a 125psi.any ideas?
The Cfm is cubic feet per minute it is based on the size of the cylinder . Your psi is determined by the pressure switch Which some models you can pop the cap and crank up a bit, but the tank itself is the big factor in the PSI of the compressor, as they are designed to hold only so many PSI safely.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
