Second Chance wrote:
1. Toilet will have water supplied by on-board fresh water system and water pump.
2. Yes - leave the water pump on all the time. It is pressure-switched.
3. Correct - when on "city" water, turn water pump off.
4. Without shore power, frig will operate on propane (unless you have a residential frig)
You don't say what kind of rig you have, but some RVs have a water manifold with valve(s) and you must set the valve(s) correctly for use of city water, on-board fresh tank, or for filling the fresh tank.
Rob
I agree with Rob, with the exception of number two. If you leave the RV, turn off the pump. If you developed a leak, the pump would continue to pump water into the rig until you returned or the water tank ran out of water. For that matter, if you are hooked to city water, I'd suggest shutting it off also if you'll be leaving the RV for an period of time.
Jim
