Matt_Colie
Aug 15, 2019Explorer II
Dive,
If you are that far from anything, why do you think that a Wifi amp will do you any good at all?
If you think it might, then go for an add-on USB 802.11 called Alfa. they are inexpensive and when I do use mine, I can often work with an access point I can't see.
What you probably will do better with, if I understand you correctly, would be to use your smartphone as an internet access hot spot. And if the places you go have bed coverage, then get a dedicated repeater (aka booster) like a WeBoost or other and put up a good outside antenna.
Matt
Matt
About RV Newbies
