rvshrinker
Aug 24, 2018Explorer III
Annual clean/wax/seal
Between the maintenance guide and the dealer recommendation, it seems I should wash, wax, and seal my trailer at least once a year. I hope to have it garaged by this winter so after that the UV and rain damage should be minimized.
I also have a window lube and slide use which I’ve applied and will do 1-2 times per year or as necesary.
That said, what products or techniques do you recommend?
Do I wash, then wax, then seal? Or wash, then seal, then wax?
In addition to all this is there an additional roof sealant I need to apply?
As for sealant, the dealer will sell me some product I cannot now remember, which they say is what they use to seal leaks. Apparently applied with a caulking gun. Dealer suggested i go around and scrape off all the old, dried sealant and reapply. However, do I really get rid of everything? Or just the cracked, dried bits? This stuff will flow into and fill any gaps, but obviously any really loose junky stuff I should get rid of first.
I’ve never waxed anything this big, so also would appreciate some tips on how to do this.
