jking006's avatar
jking006
antifreeze in fresh water tank
hello every one,
I bought a class c last summer that needed some mechanical work.
long story short is most mechanical work is done and looking forward to taking a few trips this summer.. It has been sitting for a few years and was winterized the entire time it sat.. however someone put about 5 gallons of the antifreeze in the tank.
my question is whats best to clean it out and is the tank still safe to use for fresh potable water????
  • I am not sure what type it is.. it is redish color so I would assume it is the rv potable stuff.. I do know it stinks pretty bad.. I opened the faucet on the galley sink before I knew it was in the tanks and a really bad odor came out that sent me outside gagging..
  • Drain it, flush it WELL. flush lines, If it was RV antifreeze, OK to drink, Radiator antifreeze, flush a lot more with city water, Maybe do the bleach sanitize thing, OK to use. Either case may have a bit of residual odor or taste, should not be any problem health wise. It will go away, but may take a while. Reason to use city water is for the chlorine used to purify. Bleach cycle does the same, bleach taste is better than antifreeze.
  • Do you know what kind of antifreeze? Potable or not potable?
