path1 wrote:
Anybody tour a RV manufacture and notice how they put on caulking?
Do they use some type of machine? I don't see how a person could get it as perfect as some look.
I've looked at about every video and tips for putting the stuff on.
I'm getting better but still not 100% happy with end result.
If your final result looks like you used a laser or some type of pressure gun,
What are your secrets?
You would be amazed at how good some guys can get with a caulking gun.
Ever seen a replacement window company caulk the seams after they have finished? Usually perfectly straight and even.
That being said, I doubt the RV manufacturers use a caulking gun such as you or I would, it is probably a gun on a hose pressure fed from a 55 gallon barrel of the stuff.
