Use epoxy, the same thing they use in boat building and repair. The process is the same/
Lightly sand the old fiberglass back. Remove all dust and and just before applying the epoxy wipe down the fiberglass with acetone. Only the wood needs a first coat of unthickened epoxy. Do not let that first coat fully cure because you want it to chemically bond with the second coat.
Thickening the epoxy is a good idea for the final bonding, but they you might need a notched trowel to get even coat. Clamping the fiberglass to the wood substrate is important. This will be difficult on a large are unless it is laying flat and then you can just use weights.
