RBPerry
Sep 21, 2015Explorer
With gas most have the fuel pump in the tank. the fuel is also returned to the tank via a return line. So when installing two tanks in a gas vehicle you don't use a crossover. You would install a fuel pump in and return line in the new extra tank, or at least I would. This would be a lot of work though.
You could use a crossover or transfer between the two if you wanted to, and that would be the easiest way.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
