SCADAMAN29325's avatar
SCADAMAN29325
Explorer II
Mar 20, 2023
Awning arm does not release.
We were shown how to use the awning several times, but now one arm is not releasing to be able to roll out.
I've also watched a few videos and had a couple of seasoned campers stop by that saw my struggle.
I unscrewed the knob a few turns on each arm, released the side latches and released the top latch. When I pull the lanyard, the right side (with the top latch) will pull out about 6 inches, but the other arm is stuck and puts it in a bind.
The right arm with the top latch is free to move, but the other arm is stuck in the latched position. Climbed on top grabbed the stuck arm and pulled/yanked/pushed and it will not budge.
It's a Carefree, one of the passers-by has the same awning and showed me how his works and tried mine, but it didn't work for him either.
I now have it latched and stowed for travel, but perturbed I can't use our awning.
Any help out there for my awning situation is much appreciated!
Thanks!
  • Sounds like awning arms may not be square causing the one side to jam when closed. Might try LIGHTLY tapping each side at the top with a hammer.
  • Mine sometimes gets jammed at the top. to fix it I have to push it to one side or the other (like front to back not in and out) and it eventually releases.
