HellFyre
Jun 13, 2016Explorer
rexlion wrote:
So it's not coming from the kitchen sink drain? My first thought was that you don't have a P-trap in the pipe (or the P-trap is empty for some reason).
No, not really. I stuck my nose right by the faucet which was only a few inches away from the drain, and didn't smell anything. Furthermore we had used the sink previously so there should be water in the P-Trap.
sch911 wrote:
Check the air admittance check valve under the Kitchen counter, it has most likely failed.
Never heard of this! I will check it out! Would this cause the smell to emanate from valve area instead of the drain in the sink? Because, as I responded to rexlion it doesn't appear to come from the drain. But if it's coming from this valve (assuming I have one) that the smell could be coming up from between the sink and stove, which would make sense.
Thanks!
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
