path1ExplorerJul 25, 2019Battery cut off switchOut of couriuosly, do oem"s install battery cut off switches to cut all power or leave some power "un-interuped". (Wondering if my tt is wired right.)
LynnmorExplorer IIJul 26, 2019Some factory installs do not turn off everything and that needs corrected. I also connect the breakaway wiring after the switch so that I can quickly disconnect power if there is a short rather than watch the wiring burn or worse.
Related ContentBattery & cut off switchbattery cut off switchBattery Cut Off SwitchSwitching toiletsBattery cut off switch
