path1ExplorerJul 25, 2019Battery cut off switchOut of couriuosly, do oem"s install battery cut off switches to cut all power or leave some power "un-interuped". (Wondering if my tt is wired right.)
azdryheatExplorerJul 26, 2019Depends on the RV maker as to what works with the battery switch turned off. I've seen some where the slides work with the battery turned off. Then there are some trailers, North Trail for instance, that has no disconnect.
Related ContentBattery & cut off switchbattery cut off switchBattery Cut Off SwitchSwitching toiletsBattery cut off switch
