Bobbo
Nov 18, 2017Explorer III
The Winnebago Outlook I had for 10 years had the cutoff switch disconnect everything.
The Airstream FC 23FB I have now leaves the propane detector, solar chargers, breakaway switch, tongue jack and inverter powered. I moved the hot wire for the propane detector so it cuts off with the disconnect. I put a separate disconnect switch on the inverter. I left the tongue jack, breakaway switch and solar chargers directly connected to the battery.
It all depends on how the manufacturer built it. There is no standard.
About RV Newbies
