leftys
Jan 23, 2015Explorer
Battery Life
Many posts advice you to use the battery disconnect switch to avoid battery drain while in storage. My question is, if my motorhome storage facility has power available does it make sense to keep the ...
Jbrowland wrote:
A tiny bit off topic...
So does one need to use a battery disconnect switch if they use their RV say once a month? And if so, it takes only 60 seconds to disconnect my battery manually. Why not do that instead?
