Jim_Shoe's avatar
Jim_Shoe
Explorer II
Dec 04, 2014
Before pulling out...
I read this tip somewhere and it really works. You need:
A suitable sized Ziploc bag.
A package of spring loaded cloths pins.
A felt tip marker.
Its easy to forget to do something or unhook something before leaving a CG. Especially if you stop to talk. Make a list of everything you need to do before pulling out. Examples: "Unhook and stow the electric cord", "Roll up and store the water hose", "Retract the jacks". Then write a short reminder of each item on a clothes pin. "Jacks", "Power", "Water", "Slinky", etc.
When setting up, fold the sun visor down. Then take the appropriate cloths pin and attach it to the sun visor as you complete each step. Reverse the process before leaving. What you haven't done yet is right in your face as soon as you get behind the wheel.
I've seen posts on here of people driving away with something still connected. That can be very expensive or at least messy.
  • Old-Biscuit wrote:
    GF does a complete walk around.........then I do one.
    When done we pull wheel chocks and go.
    If both of us miss something.......then we deserve it.
    Yep. I've done a walk around and still managed to drive away while hooked to shore power.
    A second set of eyes would make a difference.
  • GF does a complete walk around.........then I do one.
  • I just use a fine felt-tip marker to print the item of concern on wooden clothespins.
    Cheap & works for me!!
    I put them on the steering wheel as I setup and then as I get ready to go, I pull them and put them into the storage bag.
    (When you have 'Pulled All of the Pins', you are ready to go!!):B
  • ncrowley wrote:
    I use these:
    http://www.rvminders.com/
    I love them. They come with common reminders and some you can write on yourself. They wrap around the steering wheel so you are definitely reminded before you pull out.
    X2. I love em. On the blank ones I wrote "Propane On" an "E-brake On" (the e-brake light doesn't work, so this way I always know when I have it set).
  • The one thing I never forget as the last step is making sure all power is shut off inside the trailer (water heater, pump, main lights etc.) All of those switches are behind a panel near the door. The panel is left open our entire stay. I put my reminders on that panel.
    I don't care for the steering wheel method as we use our TV for daily trips.
  • I use these:
