sgfrye
Jul 23, 2019Explorer
NMDriver2 wrote:
Most camp sites will only be 2-4 inches off level side to side. Rarely (2-4 times in 15 yrs) have I needed more than that. Most of the time, in a commercial park, the pad was level or only a inch or two off. A little shovel work can help in even a bad site.
Keep it simple. Start with four or five 2x8x12 planks with beveled ends and two or three 1x8x12. They will last longer if you glue and screw a 1/4 inch chip board or similar composite to them to avoid cracking and splitting.
Carry a bottle jack and a shovel to change tires. There will be times when the axle will be to close to the ground, after a flat, and you will need to dig a hole for the jack. The shovel is good for other things around the camp site and can even help getting you level.
Generally the taller the stabilizers are the more wobble you will get. I try to lower them as little as possible and carry spare leveling boards just for the stabilizers to land on.
i second all of this. don't forget to chock tires.
About RV Newbies
