skipnchar
Jul 03, 2014Explorer
One of the leading causes of odors is a dry black tank which makes remaining solids permanent. I agree that your seals MAY need replacing or your P Traps were almost CERTAINLY dry causing problems. Was there any remaining water in the toilet BOWEL? If it was dry and you had sufficient water in it when it was stored, that would be an indicator that the seal is leaking also.
About RV Newbies
4,026 PostsLatest Activity: Jun 15, 2017
