Clay_L
Jul 16, 2015Explorer
lanerd wrote:
I'm with Bob. You don't need to spend your hard earned $$ on these so-call "needed" chemicals. They are NOT needed. Simply use lots of water when draining, and add several gallons after cleaning.
As others have mentioned, when getting ready to travel, put a couple of gallons in the tank and add some laundry detergent (I use liquid Oxy Clean). The rocking motion of the trailer while traveling will slosh around the soapy water and clean the inside of the tank.
You don't need the blue stuff at all.
Ron
YEP.
About RV Newbies
