foxxxnickExplorerAug 18, 2023BMS QuestionsIf I have a 12vdc 100AH battery that has a BMS in it that is 100A max discharge, does this mean if I parallel two of them together I can do a max 200A discharge now? I want to make sure my BMS will...Show More
wa8yxmExplorer IIIAug 18, 2023In theory the answer is yes. in practice I'd not wish to push it much beyond 180. I'd fuse both batteries at 90-100 amps each.. Just to be safe.(if one fuse blows the other will follow very fast)What are you feeding? A 2,000 watt inverter?
Related ContentDaly BMS gone crazy..Update OpinionsVictron BMS 712 ?Newbie power questionAnother solar question.Dicor Lap Sealant Question
