2012Coleman
Feb 21, 2017Explorer II
I've been using cargurus.com to search for a used SRW 3500. I like it better than most others I've used. Are you looking for the SRW because it would also be used as a daily driver? Do you know what kind of Fifth wheel you want and how to figure out pin weight? Since you plan on full timing it, you should follow the advice to choose the fiver before buying a TV.
Good luck to you!
Good luck to you!
About RV Newbies
