JWP127
Nov 21, 2017Explorer
coolmom42 wrote:
You do want a water heater bypass, unless you live somewhere that you don't need to winterize. Otherwise you will have to fill the water heater with antifreeze, before you get any antifreeze in the hot water lines. Aside from being a big waste of antifreeze, it's a PITA to get OUT of the water heater in the spring.
I thought so too until he showed me that you can drain the hot water heater, by removing a cap, and then opening up all the faucets and blow air into the pipes. Does this sound correct?
About RV Newbies
