SoundGuy
Nov 21, 2017Explorer
coolmom42 wrote:
You do want a water heater bypass, unless you live somewhere that you don't need to winterize. Otherwise you will have to fill the water heater with antifreeze, before you get any antifreeze in the hot water lines. Aside from being a big waste of antifreeze, it's a PITA to get OUT of the water heater in the spring.
Filling the water heater tank with antifreeze isn't necessary at all even without a bypass kit. Once you've drained the tank just disconnect the intake and output lines to / from the tank and barrel them together - instant bypass. OR just install your own water heater bypass kit ... no biggie at all.
About RV Newbies
