midnightsadie wrote:
might buy a good used rv now and use it on week ends to see what you really want. and a great learning tool.some times bigger is not better.
This!
If you are able, buy something now with the expectation you will replace it after you use it for awhile, to figure out what you really want.
If you go the 5th/TT route, get a tow vehicle larger than what you "need" - it makes for much nicer towing.
With a motorhome (Class A), definitely plan on having a "toad" - small vehicle towed behind the motorhome.
Oh, and listen to the "fulltimers" - of which, I am not one (yet, at least!).
Weird thing - when typing this response, "motorhome" came up as incorrect - the autocorrect wanted to change it to "motor home", with that space added. Hmmm.....
