luvcycles2ExplorerNov 09, 2015bypass valveHi all. may be a dumb ? but can anyone tell me if in bypass mode should I get water from the hot and cold side of the faucet? Thanks Phil
korbeExplorerNov 09, 2015My manual valve configuration routes the cold water inlet to the hot water outlet at the tank. So in my case, the cold water will run through the hot water lines.
Related ContentWater Heater bypass valve.Water Heater Bypass Valve - How To ReplaceHot water tank bypass valvesHot Water Heater Bypass ValvesReplacing Water Heater Bypass Valve
