luvcycles2ExplorerNov 09, 2015bypass valveHi all. may be a dumb ? but can anyone tell me if in bypass mode should I get water from the hot and cold side of the faucet? Thanks Phil
Artum_SnowbirdExplorerNov 09, 2015Yes you should... all you have done is disconnected the hot water tank from the flow. It must operate this way so that you can winterize with antifreeze in all your hot and cold water lines EXCEPT the hot water tank!
Related ContentWater Heater bypass valve.Water Heater Bypass Valve - How To ReplaceHot water tank bypass valvesHot Water Heater Bypass ValvesReplacing Water Heater Bypass Valve
