luvcycles2ExplorerNov 09, 2015bypass valveHi all. may be a dumb ? but can anyone tell me if in bypass mode should I get water from the hot and cold side of the faucet? Thanks Phil
HondavalkExplorer IINov 09, 2015If you only have one valve on the inlet side then you are shutting off water completely to the hot side. I would look again to make sure your not missing a valve that is currently closed between the hot and cold water lines.
Related ContentWater Heater bypass valve.Water Heater Bypass Valve - How To ReplaceHot water tank bypass valvesHot Water Heater Bypass ValvesReplacing Water Heater Bypass Valve
