luvcycles2
Nov 09, 2015Explorer
bypass valve
Hi all. may be a dumb ? but can anyone tell me if in bypass mode should I get water from the hot and cold side of the faucet?  Thanks   Phil
Hondavalk wrote:The one valve bypass system will send water to the bypass line and the check valve at the hot water outlet side stops it from going into the water heater. The cold water will travel up the bypass line and flow out the hot water lines and faucets.
If you only have one valve on the inlet side then you are shutting off water completely to the hot side. ....
