2oldman
Sep 04, 2020Explorer II
clintbrooks1767 wrote:I did some research and yes, it can approach zero degrees. But the way you worded it it may be mistaken for "below zero." That's way too cold to be in an RV.
I've been skiing in NM for almost 20 years and the temperature routinely can get to 20 or 30 degrees BELOW freezing..
5-10 degrees will not be pleasant. Like your a/c trying to keep you cool when it's really hot, your heater will likely be running 24/7, and you will need LOTS of propane.
About RV Newbies
