JimK-NY
Sep 04, 2020Explorer II
GordonThree wrote:
Sheesh lots of naysayers and fraidy cats on here!
Have you camped in sub zero temperatures? The typical RV might do OK down to freezing but is just not likely to do well below zero. Even if the RV is set up to avoid frozen valves, pipes, and tanks, it will require LOTS of propane just to keep it useable. Condensation is likely to be another big issue. Water can condense on aluminum window frames and vent covers making them inoperable.
About RV Newbies
