JimK-NY
Sep 05, 2020Explorer II
Killing a 30# propane tank per day sounds about right. Even then the RV is not going to be comfortable. Be sure doors and emergency exits continue to work without being frozen shut. Open doors on any cabinets on exterior walls which are used for storing liquids. Never turn off your HW heater. The tank will freeze quickly. Check the entire RV and add insulation where possible. For example, exterior compartment doors are typically not insulated. Forget about showers and be careful with cooking to minimize any steam. Even then you will need some ventilation to minimize condensation and ice build up on interior surfaces.
About RV Newbies
