JimK-NY
Sep 05, 2020Explorer II
memtb wrote:
..It takes a pretty good RV to live comfortably in those temps. Ours was a 1990 Teton with a -20 or -30 F guarantee...... memtb
I suspect this is why we have so many differing opinions. I can say for sure that my RV was not designed to handle low temps. It does sort of OK down to a bit below freezing. Below that it will be drafty inside and the furnace will need to run frequently.
In cool damp weather frost on the exterior will show the RV construction. The walls are braced with 1x3 slats. Between the slats there is cheap 3/4" rigid foam.
About RV Newbies
