Grumpy374
Mar 21, 2016Explorer
PatRenee wrote:
I bought the cup holder that you mount to the wall and place your cup or glass in it... I thought it would be great beside my theater seat on the slide wall.... I bought several things from Camper World and have since found the same items cheaper elsewhere.... I wasn't going to complain because I bought them.... But I went to mount my drink holder and it clearly has 6(six) mounting holes which is a great design... the only problem is our friends at CW only include 2(TWO) screws to mount it with...... HOW F>>>>>ING CHEAP are you that you couldn't put 6 screws so it won't rip out my wall....
right click on the word image above then click view image to see it.... thanks
If you own an rv, you had better be a "do it yourselfer" or a "mr. fixit". If not, get a Prius and stay at Motel 6. If all your ranting about is a few screws, then go to your supply of assorted screws, nuts, bolts, and use a few. You should be carring that, repair duct tape, wire ties, xtra fuses, and a lot of little things to repair, fix, modify your rv.
This is just day to day minor stuff that we all put up with and accept as part of owning an rv. Get used to it.
Grumpy
About RV Newbies
