rwbradley
May 05, 2014Explorer
Campsite Electrical
I am new to RVing, just graduated from tent camping to a 20ft Hybrid. I have been looking thru the forums learning as much as I can. I am curious about feedback on one area in particular. I have been reading about Surge Guards and the different things they can protect the TT from. There appears to be a lot of opinion about the value of having them vs their cost. I will likely invest the money in one, but in the short term, I would like to make sure I understand how to diagnose site wiring faults at the site. I have a decent multi meter in my toolkit.
I think I understand what to test and how, but want to confirm if my assumptions are right.
My TT is 30A, so if the ground (round prong) is up the hot wire would be left and neutral right. If I plug into a 15/20A service with a dog bone, pin out is the same. If I plug into a 50A service with a dog bone, if ground (round prong) is up, left and right are both hot and bottom is neutral.
- I should be able to see +105-125v from Hot to Neutral and Hot to Ground
- If I get a negative number testing hot and neutral, they are reversed
- If I do not get a reading hot to ground there is a ground fault
I assume if any of these are found, it could cause a serious electrical issue.
Are my assumptions correct or is there anything else I missed or worth knowing about verifying site electrical?
Thanks
Thanks
