BeatCJ
Nov 05, 2016Explorer
juggledog wrote:rhagfo wrote:
Use a small air compressor and blow out the lines, no need for the antifreeze. We use the 5er all winter and have done this several times in a winter, or like last year once! Never got cold enough after our New Years trip.
Yeah, I think this is what I'll do. I already have an air compressor, so it makes sense.
Since you're from Portland, do you have any cool spots I should take the RV over the winter? I was told it's fun to watch the storms on the coast.
Make sure your compressor is oil-less, otherwise you can create a nasty taste in your water system. I live about 30 miles NE of Portland, and some years I don't have to winterize, others I do. Since we are in a region that is relatively easy to forecast, we usually know if we are going to approach freezing. If i hear we may get to 35 F, I take the time to do it. I keep antifreeze on hand for the traps and tanks, and have a small compressor, if you hurry, you can do it in less than 30 minutes. Like was mentioned, getting the water pump safe is the hardest part. You don't say if you store your RV at home, If so, a small electric heater plugged in with the cabinet open to you water pump is cheap insurance.
I like Cape Disappointment and any park on the coast in the winter, they are so peaceful. I can go for a couple of days (we have our time off in the middle of the week) on just batteries. I also like Central Oregon or Washington, the High Desert areas are great to get away from the rain for a break. Get into the rain shadow of the Cascades, and it can be a great break. I like The Malheur, Blue Mountains, Lakewood areas. You don't have to go that far, and you may have to adjust travel plans due to pass conditions. In a Class C, you are a little more mobile than a trailer. I hate towing on icy roads, so I avoid it if I possibly can.
About RV Newbies
4,032 PostsLatest Activity: Apr 08, 2026
