Grit_dog
Jan 19, 2016Navigator III
Awesome! Did you get the heat hooked up too?
IMO as long as you test run it a while to make sure everything's good then no issue leaving it on for as long as you want, as long as the batteries keep a charge.
I routinely run the fridge on propane for hours to days when not around it.
It's not an issue and uses very little propane.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
