mlts22
Jan 22, 2016Explorer II
pianotuna wrote:
Parasitic loads may be up to 36 amp-hours per day.
Take the size of the battery bank in amp-hours and divide by 72. That may indicate the number of days that the fridge can be run without damaging the battery bank from too deep a discharge.
Thanks for the figure. I wondered how many amps the fridge's control board used... I knew one battery wouldn't last a week, so this week, decided to go with a few in parallel. Normally, I just shut the fridge off when not using my rig on weekends, but trying to see if my beefed up battery bank will handle it.
This is a Dometic two-way fridge that runs on propane or 120VAC... but if the battery voltage drops under 11 volts, it pops the check light on and turns itself off.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
