Old-Biscuit
May 28, 2015Explorer III
paulcardoza wrote:
The real answer depends on your level of paranoia. There is no reason whatsoever to turn off the propane while traveling with your RV.
I'm not even aware of the requirement to turn them off in selected tunnels. I have seen many tunnels that prohibit propane altogether, but have not seen any that tell me I can bring it in, but all appliances using it must be off.
There's nothing in my water heater, furnace or RV manuals that caution me about the need to turn off Propane at fuel stops. There are no such warning labels on the appliances.
I have never seen a news story about an RV Propane appliance causing a fuel station explosion. Maybe someone can point me to such an example?
So many folks do everything possible to turn RVing into a chore, instead of a relaxing, enjoyable adventure. The level of paranoia is astounding..........
Just some of the tunnel restrictions
Maryland
Chesapeake Bay Bridge
Pennsylvania Turnpike Tunnels:
Hello,
Thank you for taking the time to contact the Pennsylvania Turnpike Commission. In response to your email you are permitted to carry up to 100 pounds of propane through the tunnels at one time. The only restriction is it must be turned off only while traveling through all of the tunnels.
Sincerely,
Marsha Coble
1-800-331-3414
717-939-9551 ext. 5830.
Hours are Monday through Friday, 8:30 A.M. to 4:30 P.M
Appropriate Signage is posted PRIOR to entrances.
About RV Newbies
