wanderingaimles
Mar 24, 2019Explorer
As you questioned the 1000 lb capacity of the tt is limiting. If you can travel with only 10-20 gallons because you will be staying somewhere with hookups, you should be fine.
Boondocking with 48 gallons of water after having added 2 batteries and 2 propane tanks will get that CCC filled up quick.
Tow vehicle wise, you look to have a good match. Just verify the use of the weight distributing hitch on the unibody, not sure if that could be a question or not.
About RV Newbies
