Rvbewbie101
Mar 24, 2019Explorer
Grit dog wrote:
Drivetrain will handle towing that weight pretty much no problem.
Rear suspension, keep weight in check, IMO. Idk what is available for upgraded struts or springs, but being an independent rear suspension, it's not a traditional solid axle that is more durable for weight rating, again in my opinion. You're towing with a "car" suspension.
This is what I could find about the rear suspension, it’s mostly jibberish to me :?
Multi-link rear suspension, coil spring, twin tube shocks (including load leveling for towing), aluminum lower control arm, independent upper links (tension and camber) plus a separate toe link
About RV Newbies
