Lady_Katie's avatar
Lady_Katie
Explorer II
Sep 09, 2015
Can you buy an empty travel trailer?
Hi there! My husband and I are just starting to consider getting a travel trailer. I'm pretty attracted to 5th wheel trailers, but we'd have to get a truck to tow it. Either way, I'm kind of interested in completely customizing a trailer to suit our family and my very picky taste. Is it possible to purchase an empty trailer shell? We'll probably just end up buying an older model with good bones and gutting it, but I figured id pop on here and see if there are other options. Thanks!
  • Check on You Tube for videos of TTs being assembled. Looks like they do it from the inside out. May be hard to attach the walls if the inside was empty.
  • You can't just put everything where you may like it to be. Sme items are heavy and some are very light. Even the cheapest RVs have some sort of thought that goes into weight distribution and balance.
  • Not that I've seen. I did a complete gut and rebuild. The demolition part of the project probably involved a day or so of labor. Depending on how you wish to outfit the mechanicals, buying a working trailer and saving the appliances and plumbing fittings would save a good bit of money over buying new. I only saved the bathroom sink and countertop, the shower stall, and the toilet. The restoration thread is in my signature line.
    Here is a guy that knows a few things about building a travel trailer:Adirondack Airstream
  • If you are thinking of building your own trailer I would recommend that you see this video. There is a lot of what goes into the building of a trailer that you do not see. I have rebuilt water damaged areas of a trailer and I can attest to what you will find when you have to disassemble to do the work. I have replaced the entire plumbing water, Potable water, on a trailer and it was no easy task. There is 12 volt wire, 120 volt wire, LP gas lines, water lines, drain lines, AC duct, floor duct for furnace, Light weight cabinets, etc.
    https://www.youtube.com/watch?v=jXMJrRQ3SVk&safe=active
    There are companies that Custom build trailers, but they are quite expensive.:)
