Wisconsin_BumsExplorerDec 17, 2017Caulk removerHave slide out that has real hard caulk on it.used a plastic putty knife, does not work.I do not want to ruin the clear coat on the slide out. Help
VeebyesExplorer IIDec 17, 2017When you replace it & want a smooth bead here is a trick. You can never get it smooth & neat with just the gun.Tape either side. Apply, not too much. Smooth over with an ice cube. It will not drag like a tool.
Related ContentCaulking Removal...Staple RemovalCaulking removers - cautionCaulk removalRemoving silicone caulk
