Wisconsin_BumsExplorerDec 17, 2017Caulk removerHave slide out that has real hard caulk on it.used a plastic putty knife, does not work.I do not want to ruin the clear coat on the slide out. Help
Garry_GayleExplorerDec 18, 2017Use the tool in the Homax kit, lay your bead of caulk then spray the area with soapy water then using the tool smooth; several youtube videos on this method.
Related ContentCaulking Removal...Staple RemovalCaulking removers - cautionCaulk removalRemoving silicone caulk
