With regards to turning the water off when you leave the RV for the day: I full time so I will do both at different times. When I am home for the weekend and don't go anywhere, I will run off city water and use and adjustable water regulator (set at 60 psi) so I get a little better pressure when showering. When I am working during the week, I will use the fresh water tank and the pump. The reason I do it this way is because it is easier for me to turn the water off from inside the RV using the water pump switch. The hose spigot is on the opposite side of my RV as the doors. I turn mine off when not at the RV to prevent any possible damage from a possible leak. I know it is unlikely but it is a simple step I do not mind doing to prevent damage to my home.
